loop synchronization in CRIO
Hello:
I am working with the FPGA in the CRIO and I would like to synchronize some loops inside the FPGA code (for start everyone at the same time), I thought that the best idea is used timed loops with a common clock, but I want to carry out these loops at 1 KHz and the the closest clock that can I derived from the FPGA is 2.5 MHz, how could I create a clock of 1kHz?
Or maybe another for synchronize these loops?
Thanks in advance!
Regards
Alvaro
Message 1 of 8
(4,719 Views)
I dont think you need a derived clock. Just set the loops dt to 1 ms. But, that said, i havent had to do synchronization of loops on fpga
Message 2 of 8
(4,717 Views)
The problem is that in the timed loop of the FPGA I can´t establish a desired period, I can ony select a certain clock.
Message 3 of 8
(4,707 Views)
Id be curious if you are setting this up right but I am on my phone right now so I cant test it. You can always just put a 1 ms wait in the loop, but that will always make the loop return "finished late?" as true.
Edit: have you tried double clicking the loop to open the timed loop configuration?
Message 4 of 8
(4,704 Views)
My bad youre right. You can do it with waits in your loops id always suggest searching the knowledgebase first.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019QhXSAU&l=en-US
Message 5 of 8
(4,698 Views)
If I put a 1 ms in the a wait of the loop it will give a return late, because the loop execution takes a certain time plus the 1 ms of the wait, so at the end my loop will be carried out in more than 1 ms. And also the loops will not being synchronized because the different loops take different times for the execution, a loop that takes 0.001 ms will be execute the secont time at the time 1.001 (1+0.001) and a loop that takes 0.002 ms will be executed at the time 1.002 ms, isnt it?
In the configuration of the time loop only appears the avaliable clocks(I attacht screen capture).
Regards!
Message 6 of 8
(4,690 Views)
You are not required to use a timed loop for what you are trying to do. If you feel you MUST use time loops you can use them and let them run faster. Do a cacluation of time elapsed, then when 1 ms is up, send a software trigger (see section #2) to your other loop telling it to execute. You could also do this with a digital output instead. Then reset your timer and do it again.
 Please, do a search as was suggested
Message 7 of 8
(4,683 Views)
Personally I like to do this using a single-cycle timed loop containing a case structure. Count until you reach the right number of ticks for the desired period, then reset the counter to 0. Put your logic inside the 0 case (or, if timing doesn't allow all the logic to fit in one loop cycle, spread it across several cases).
Message 8 of 8
(4,665 Views)
