loops, timers and errors
Use this timer, u wont miss the events.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 21 of 35
(1,895 Views)
Ravens Fan: Is this an ordinairy case structure? I don't recognize the green frame.
Message 22 of 35
(1,887 Views)
Ravens Fan: No need to reply, I figured this one out myself 🙂
Message 23 of 35
(1,883 Views)
Baji:
About the "First Misstake". If I insert the instrument as you describe I get stuck in an infinite loop, as the program will never read anything. Occasionally I will get a warning saying that there might be more bytes at port than I requested to read.
Message 24 of 35
(1,876 Views)
I hav made a new version of getstring.vi. It checks for errors, but it still gets stuck in the second loop, despite getting an 'Á', indicating EOF.
I have put the indicator withthe read string inside the case structure. Is this the right thing to do?
Message 25 of 35
(1,869 Views)
Baji: I can't open timer.vi. I use LabVIEW 8.5.
Message 26 of 35
(1,860 Views)
Timer Vi in 8.5
Balaji PK (CLA)
Message 27 of 35
(1,849 Views)
First check the available bytes in the port, Read the port if available bytes are more than zero (Implement this using the functions - Bytes at port,Greater than zero and a cade structure).Dont read the port if no bytes are available.
Balaji PK (CLA)
Message 28 of 35
(1,846 Views)
I thought the function you inserted were supposed to do that. Do I need to change it further?
The timer.vi is still in 8.6.
Message 29 of 35
(1,824 Views)
I think I figured this one out. Connecting the numeric wire from Bytes at Port to the VISA read function seems clever, but that makes it incompatible with getstring. The way getstring works it is supposed to only read one character at a time, looking for EOF, which it won't find, since it keeps getting larger chunks of text, hence infinite loop.
I include new version of serial port control.
Message 30 of 35
(1,821 Views)
