losing digits with numeric conversion
Labview is removing trailing zero's at the left. It's working numerical.
But I want to do binary conversions and don't want the trailing zero's to be touched because I use it for vesion numbering.
How to keep them?
(3,594 Views)
Please explain your problem better, are you converting between string and datatype? Do you want to see all 0's in a indicator?
For the indicator you can change it's Properties to show extra zeroes, for conversion there's a bunch of ways.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,592 Views)
Following example removes the left zero's.
(3,589 Views)
Hi JoVMo,
You can right click the numberic indicator and click on "Display Format..."
There is a tick box that says "Use minimum field width".
Tick that and select the number of digits you want to display.
There is then a drop down menu that allows you to select:
Pad with spaces on the left
Pad with spaces on the right
Pad with zeros on the left
Steve
Stephen C
(3,584 Views)
And a conversion back to string let it drop the zero's. ??
(3,582 Views)
Use the "Format Value" function with a format specifier of %08B (8 binary characters).
Hope this helps.
Steve
Stephen C
(3,577 Views)
