luminance image by pca
hi!
i have to get luminance image of an original image by applying pca on the originol one. i have done my work but here is a problem. i want to get luminance image by applying pca but the resultant image is not clear. here is the attached vi. would u plz  see it and correct it for me? i have got the luminance image through many simple ways but i have to do this by pca. i think the problem is in the final result, the result of multiplication , i have to increase its values by some way. but i dont know that way.. kindly help me.
thnx in advanc
(2,825 Views)
You can find an example of how to use the TSA Principal Component Analysis VI in labview\examples\Time Series Analysis\TSAGettingStarted.llb. I would compare your VI to the example and see if your VI is set up in a similar way.
(2,799 Views)
thnx 🙂
but plz do this as soon as possible...
thnx again
(2,794 Views)
