luminosity sensor
hi to everybody i need the solution for luminosity sensor i draw the circuit for to sens the sensor now i need this two solutions for labview 8.
You’ll place a push button to make the value of maximum equal to zero when push. This button must go back
Automatically to off state when released.
Connect a led on the daqboard on the output voltage number 0.
Modify the program to light the with an intensity inverse from the value of the light measured.
If low light, the led bright a lot; if high light the led is off; if medium light the led bright medium.
Make test with Max before Programming to determine the value of voltage to send to the for
Lightning.
Message 1 of 1
(2,661 Views)
