luminosity sensor
hi to everybody i need the solution for luminosity sensor i draw the circuit for to sens the sensor now i need this two solutions for labview 8.
in attachments please look the luminositysensor.vi and document for total question.
You’ll place a push button to make the value of maximum equal to zero when push. This button must go back
Automatically to off state when released.
Connect a led on the daqboard on the output voltage number 0.
Modify the program to light the with an intensity inverse from the value of the light measured.
If low light, the led bright a lot; if high light the led is off; if medium light the led bright medium.
Make test with Max before Programming to determine the value of voltage to send to the for
Lightning.
(3,129 Views)
Looks like you have been given an assignment and you are looking for quick answer Smiley Wink
I can give you a hint where to start. Try doing it yourself and let me know if you find difficulty.
"You can use property nodes to change the color of the LED."
"For the push button use any Boolean control and play around with its Mechanical properties "
Anyways if you still have a problem   save the above vi in Labview 7.1 as I do not have 8.1 with me..
Good Luck
Regards
I am unable to open you vi.
CLAD
Using Labview 5.1,6.1,7.1.8.0
(3,121 Views)
I think you're going to have to study a bit harder. It appears that you don't know the differecne between analog input and analog output.Smiley Wink Hint - you are using the wrong one.
(3,105 Views)
