lv 8.2 grab image
Dear Reut,
Please take a look at the attached VI. I've demonstrated one way in which to save the images frames as PNG files.
Hope this helps!
~Nate
Message 31 of 54
(1,482 Views)
Hi Nate
i tried to open your code in lab view 8.0 , (i couldnt get to 8.2. so i rewrite the code for labview 8.0) its seems to display image but didnt get to save the folder of files
if you can please have a look and let me know what could be the problem?
thanks a lot
Reut
Message 32 of 54
(1,460 Views)
Message Edited by reut on 05-05-2008 12:20 AM
Message 33 of 54
(1,459 Views)
sorry i attached the wrong code this is what i ment...thanks again
Message 34 of 54
(1,457 Views)
Dear Reut,
I've attached the code again saved in LabVIEW 8.0. This file save method worked for me, but I tested it with the IMAQdx driver VIs and a FireWire camera, as that is what I had hooked up to my computer at the time. If the attached code does not work, could you let me know what errors you are getting?
Thanks!
~Nate
Message 35 of 54
(1,442 Views)
Dear Nate
the code worked, but its save one pic each time, is it suppose to save the all serial of pics?
should i save it diffrently in the images folder?
i am sending you the screen saver suring running have alook and let me know if i didnt fill it good
thanks
Reut
p.s.
when i am running that with out write the path for images folder its run instantesouly
Message 36 of 54
(1,434 Views)
Dear Reut,
I've modified the code slightly, I want you to try it now with the default values that I've saved for the 'Images Folder' and the 'Run Information' controls.
The Images Folder control should read C:\Documents and Settings\reut\Desktop\trial
The Run Information control should read testpicmay
After you run and stop the VI, you should have the same number of saved image files in the trial folder as the # Frames indicator. Please let me know if this is not the case.
Best Regards,
~Nate
Message 37 of 54
(1,423 Views)
sorry for driving you crazy, but the last code is not LV 8.0 (its 8.5, please if you can to switch it for LV 8.0, thanks)
anyway, i wrote the phat of the images folder manualy, and the run information, but as soon as i connected the external trigger, the code run but doesnt react, and no image saved
so i am still in the same situation....(i am adding here the prt scr of running one of the build in example with the external trigger that used to work, but now i am getting error window, ...)
if you have any ideas what can i do, ...
thanks a lot
:womanhappy:
Message 38 of 54
(1,415 Views)
Message 39 of 54
(1,413 Views)
Dear Reut,
Sorry about the attachment; it should be saved for LabVIEW 8.0 now.
Please try this example out, as well as try a snap and a grab in MAX (Measurement & Automation Explorer). Do you get the same errors in MAX as you do in LabVIEW?
If so there are a couple of things I want you to check:
1) In MAX, make sure that you are using the correct camera file. Do this by navigating to Devices and Interfaces»NI-IMAQ Devices»InterfaceType: 1424, and make sure that you have the correct camera listed here. If not, right click on the camera listed and navigate through the Camera menu to your specific camera.
2) try disabling serial commands by unchecking the "Enable Serial Commands" box in MAX under the Camera Attributes tab.
Do you still see the error after doing both of these things?
Best Regards,
~Nate
Message 40 of 54
(1,397 Views)
