01-13-2007 08:18 PM
01-15-2007 03:09 PM
I ran the Continuous Sound VI with these settings and everything worked fine without timeout error in LabVIEW 8.2.
Tunde
01-15-2007 08:59 PM
01-17-2007 04:28 PM
I tested the VI again without error on two different machines with LabVIEW 8.2 using this configuration ( Device ID=0, Number of Samples/ch =800, Sample rate =8000, number of channels=1, bits per sample =16). I will suggest you run the VI on another machine.
Tunde
