lvdaq.dll error in migrating from LabVIEW 2013 to 2017
I have been tasked with upgrading a PXI rack running LV 2013 on Win 7 to a new rack running 2017 on Win 10. The DAQ VIs are showing as broken as they cannot see, or will not load the lvdaq.dll . I have double checked that I am using the same copy of the DLL in both cases (it was bundled up with the project).  Might there be a compatibility issue between versions?
(2,022 Views)
Are you using LabVIEW 2017 32bit or 64bit?
ʍolɟɐʇɐp ʞuıɥʇ
(1,994 Views)
I am using 32 bit LabVIEW.
(1,987 Views)
