lvdaq dll not intializing
When I Load a VI that uses the Lvdaq.dll file. LV comes up with an error describing the following:
Error Loading : C:\......\Daq\lvdaq.dll
A dynamic Link Libary (DLL) initialization reoutine failed.
Does anybody know how to fix it?
(2,985 Views)
Dear Andrew,
I have looked into this issue. It sounds to me like it is a corrupt installation of NI DAQ. I suggest that you unistall that version of ni daq on the machine, and then reinstall it. If you continue to get the same error then it is a possiblity that LabVIEW has also been corrupted. Below is a link of this problem happening before.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=50650000000800000012600000&ECategory=Measurement+Hardware.Multifunction+DAQ
The lvdaq.dll should be intialised during the installation of ni daq.
Also I advise you to istall the latest version of NI DAQ also. You can download the latest version of this driver on ni.com/downloads. NI DAQ 7.2 is the most up to date at the moment.
I ho
pe that this helps.
Kind Regards
Louis Price
(2,984 Views)
