.lvib / .llb / .lvilp Which one to choose and how to organize it?
As a followup to the TCP application based thought, which I realise might not be so clear, you could then distribute examples (using save for previous) as source code in 2011 which could be used/copied from in your clients' code (assuming they're ok with that kind of thing).
It's still not ideal, but if you're out of other options it's a possibility.
GCentral
Message 21 of 32
(1,835 Views)
@VinnyAstro wrote:
Hmmm I didn't know that nope. that is actually a big issue as I only have 2019 and I don't believe my company will be keen in buying other licenses for multiple versions ...
Your 2019 license will also work for 2011.  You can use any previous version of LabVIEW with a license for whatever version you are licensed for.
Message 22 of 32
(1,831 Views)
So I don't know yet which version they have, but if I can't build in a previous version, then I might also just end up giving them a zip file of the lvlib in whatever version they have
Message 23 of 32
(1,830 Views)
Ah good to know! Then problem solved 🙂
Message 24 of 32
(1,829 Views)
Hi again.
Quick question in term of good practice to develop my library, I think I'm not doing it very good:
I have a USB to CAN converter that came with a (not really good) labview API.
At first I simply imported it in my general library, but as I've done some changes to it and thinking that I might have to re-use the same hardware later, I thought it would be a good idea to actually have my own library "usb2can.lvlib" that I could re-use in other projects. So I just converted the owning folder to a library.
In the end I have created a library inside the original lib, and not sure if shouldn't have created it aside and then import it.
Can you advise me on the best practice to follow?
Vincent,
Message 25 of 32
(1,791 Views)
To change the hierarchy you can just drag'n'drop it so it's outside the other library.
I don't know if it's a big issue to have libs in libs, but if you plan to build this lib to a lvlibp you should probably detach it.
Qestit Systems
Certified-LabVIEW-Developer
Message 26 of 32
(1,788 Views)
Probably not what you mean, but...
A library containing a type def + some VIs == class
Take the step to real OO, you're already faking it.
Message 27 of 32
(1,783 Views)
Uuuf one step at a time ^^
I'll try to manage a library and a general development architecture properly (nothing exists in my company atm) with the knowledge I already have before getting into LOOP 😄
Message 28 of 32
(1,774 Views)
Yep so I don't necessarily plan to have build it, but eventually to source it. So I think I'll detach it and import it from somewhere else. Luckily I'm still at the beginning of the development ofmy lib, so it won't be too much work managing all this.
Message 29 of 32
(1,772 Views)
Ironically, 'we' use OO because it's easier.
Message 30 of 32
(1,770 Views)
