lvlib Add Options
I have a bunch of VI under a particular lvlib.  I thought I would organize the VIs a little, so I created multiple lvlibs under the original lvlib and organized my VIs according.  Then, I realized that under the add option, there are file, folder (snapshot), and hyperlink.  I am most interested in the folder (snapshot).  What does snapshot means?  What you explain each options a little?
Is it true that I probalby should create one lvlib and multiple folder (snapshot) under the lvlib to organize my VIs, instead of create multiple lvlibs under one lvlib?  Thanks!
Yik
Kudos and Accepted as Solution are welcome!
Message 1 of 9
(5,879 Views)
yik
yup yik,
jyang72211 wrote:
I have a bunch of Vs
Iinterested in the folder (snapshot).  What does snapshot means?  What you explain each options a little?
Yik
No- I cannot explain each snap-shot too you, and really- why would you want this!!!   your posts show that you CAN use the LV:help"
You CAN ask a better question than this one.... please do!  (Just a Grumpy old man)
Message 2 of 9
(5,869 Views)
A snapshot 'add' option is used to easily import all the files (and sub-folders) into a LabVIEW library or project. The term 'snapshot' means that only the files currently in the folder will be added.
Ton
My LabVIEW Ideas
Message 3 of 9
(5,861 Views)
Grumpy - I guess it was a bad questions.  What I should have asked is what is the preferred way of organizing files in a lvib?  Can anyone shed some lights on this?
TC - thanks for explaining this.  If you add a fold snapshot (currently have 5 VIs in it) to the lvlib and later add 2 more VIs into the folder, the snap shot folder in the lvlib will still appear to contain the 5 VIs from the moment you created the lvib, and the 2 new files will not show up there, since the snap shot doesn't update the folder?
Yik
Message 4 of 9
(5,845 Views)
Hi Jeff,
On a side note, I tried to download the free code capture tool.  When I tried to open the vi for installation, the vi try to find a component, but it is unable to do so.  Becasue of this, I can't install the tool.  Can you help?
Yik
Message 5 of 9
(5,844 Views)
Sorry about that-  I was out of line Please accept my appologies
Message 6 of 9
(5,832 Views)
Jeff,
Not a problem.
Yik
Message 7 of 9
(5,818 Views)
jyang72211 wrote:
Hi Jeff,
Yik
jyang,
could you sent a screenshot of the search for the missing component?
Have you extracted the all contents of the zip-file to a folder?
What LabVIEW version on what platform are you on?
Ton (CCT-developer)
My LabVIEW Ideas
Message 8 of 9
(5,794 Views)
You were right.  I just didn't unzip the file.  Thanks!
Yik
Message 9 of 9
(5,750 Views)
