lvlib disassociation
I have a bunch of vis and they are associated with several lvlib files.  I decided to delete the lvlib files.  Is there a way to delete all the association without opening every vi that has an association?
Yik
Kudos and Accepted as Solution are welcome!
Message 1 of 10
(4,838 Views)
Accepted by topic author jyang72211
Hmm....
Something like that?
Message 2 of 10
(4,824 Views)
This is beatiful.  How do you surpass the open function from trying to load files, since some of the files doesn't exist anymore?
Message 3 of 10
(4,815 Views)
Hint: Look in the File I/O -> Advanced File Functions palette. Go ahead. Try.
Message 4 of 10
(4,807 Views)
Ahhh!  It worked, but something bad happened.  For each vi, there are many subvi in it.  The subvis are still associated with the libraries that are no longer.  How do I fix that??  Thanks!
Message 5 of 10
(4,796 Views)
I looked all over in advance file operation, but can't find it.
Message 6 of 10
(4,795 Views)
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/utility/libraryn-llb/check-if-file-...
Message 7 of 10
(4,788 Views)
You would need to do the same thing with the directories where those subVIs are.
Message 8 of 10
(4,783 Views)
I did the same thing to the subiv, but that didn't fix the problem.  The Main VI is still tryin got find the subvi assoicated with lvlib.
Message 9 of 10
(4,740 Views)
Well, another way to do it - in project. Open your project (which contain Main.vi and lvlib with all files) then select all files within lvlib and drag these files out of lvlib. Then select File->Save all. That it.
Message 10 of 10
(4,723 Views)
