lvlib enum typedef constants reset on build
Bug report:
When building a code distribution to a 'llb' with the 'Add files to a new project library' checked, typedef enumeration constants on the block diagram are reset to their default values.
  - non-typedef enumeration constants do not have this issue
  - checking 'disconnecting type definitions' prevents this behaviour (and is a suitable work-around for my purposes)
Andrew
Message Edited by Andrew O on 03-24-2008 10:14 AM
(3,492 Views)
Can you specify a LabVIEW version? Also, do you have a small sample project displaying this behavior?
(3,477 Views)
@Andrew O wrote:
Bug report:
Andrew
I also have this issue with the version 2012 sp1.
I will try to use the workaround.
I wonder if it has been fix in newer versions.
(3,168 Views)
The fix would be to use VIPM and not an llb
(3,163 Views)
Jeff:
Actually I am using lvlib not llb, but I will try tomorrow morning to see if it works or not.
I haven´t built any VIPM, so I wonder if it is possible to call any file inside the VIPM dynamically with the RTE.
Efrain
(3,147 Views)
