lvm
In the header of a .lvm file, the number of samples appears fixed at 100, how can i change it to read more than 100. Thanks
(2,717 Views)
The number of samples is the size of the data you've collected. What are you using to acquire the data and are you sure you have more than 100 samples? Put a probe on the Signals input and check the size of the array that's being passed. If the array size is other than 100, post an example that demonstrates this behavior.
(2,695 Views)
