lvwutil32 & TS4.x with LV8.5 RTE
I am trying to complete a TS4.0.1 + LV8.5.1 RTE deployment that uses functionality within the lvwutil32 utilities.
Everything if OK with LV8.5.1 development environment but TS+LV crash out when I change over to the RTE. I believe this is because the Lvwutil32.dll needs to be rebuilt with the latest LV8.x??
Anyone experienced similar problems? and more importantly were you able to fix?
Any help appreciated - I can work around this issue, for my current small app., but these utilities are very usefull and I would like to continue using them.
PS: I have posted this message on the TestStand forum as well
Ian Burgoyne
Powerwave Tech.
Message 1 of 17
(4,469 Views)
I'm fairly confident that the LVWUtil32.dll is a C DLL.  There is no way it is a LabVIEW DLL, because it predates LabVIEW's ability to build DLL's.
Have you skipped the sections that use the DLL and confirmed that they are what's causing the problem?
Are you testing on the same PC you were using for development?  If not, it's possible you may be missing other drivers or components that you unknowingly used.  For example, recently a user I helped had used .NET controls and didn't have the same version of the .NET framework on the deployment machine as he had on his development machine, so his program wouldn't run.
Message 2 of 17
(4,460 Views)
Matthew,
IB: I have only skipped the LV call from TestStand - I will trace thru' to the DLL wrapper in LV but being a pessimist I immediately assumed the DLL was the problem
IB: Yes to same PC. I am just changing the adapter setting within TestStand
Ian
Message 3 of 17
(4,457 Views)
Matthew,
The fatal error flash screen displays the following text:"LABVIEW.LIB was not called from a LabVIEW process"
Ian
Message 4 of 17
(4,452 Views)
Can you post the VI causing the problem?
Message 5 of 17
(4,450 Views)
Will do Mathew when I return to work on Tue.
Thanks for feedback so far
Ian
Message 6 of 17
(4,438 Views)
You can also look for CINs that you are using in the VI.  If you copied a CIN, it could be causing the issue.  I suggest trying to determine exactly where the error is occuring.
Message 7 of 17
(4,433 Views)
Ian,
I have exactly the same problem as you but TS4.0 + LV8.5 RTE
I already did a Mass Compile LV8.5.
My test sequence crash out when I change over to the RTE when using "lvwutil32.dll".
How did you solve this issue?
Thanks a lot.
Axel Sanchez
Mexico
Message 8 of 17
(4,350 Views)
Sadly I have no fix at the moment - I was pulled onto other 'more important' tasks!   The normal firefighting test activities 😞
Sorry I cannot help in the short term - I never understood why this functionality is not imbedded in LabVIEW. The platform independence excuse became invalid as soon as ActiveX support was added.
Ian
Message 9 of 17
(4,331 Views)
Hi Axel and Ian,
Can one of you post an isolated version specific to this behavior so I can replicate it on my system over here? If need be, I can then get in touch with R&D and we can get to the bottom of this.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 10 of 17
(4,319 Views)
