ma_ptmcreate missing error
I get on the target PCs (XP and Win2000) four error messages during startup.
The application builder included  the LV7.1 Runtime and Datasocket support.
The program uses the soundcard to capture audio signal. The target PCs have never "seen" LV.
Any hints?
 Tomi
(3,015 Views)
Hi All,
(At home I recognised that the attachment was not properly linked.)
I do no know why the installed application reports errors about the missing vis. The application builder shows that the complained vis will be included in the exe.
Has anybody encountered this problem? The missing vis are part of the standard library (mascope.llb/Amplitude and Levels).
In the past I used these vis with LV7.0 and everything (development, appl building, installation, execution) worked well.    LV7.0 did not show such error messages.
(2,998 Views)
As these arew no standard VIs from LabView, these must be some sub-VIs of your Top-Level VI. Check your search paths, so that LabView can find these VIs.
(2,985 Views)
