I am new to Labview, only have a couple months experience using Labview 7.1.
My application is to use ultrasound to inspect a component. For every component inspected, an ultrasound wave chart is print out. I define my Y axis max and min, also define Y axis major and minor increment as 20 and 4 respectively(see attached file). However, the very first print out is not what I defined. It always the major is 10 and minor is 2.5 but the Y axis max and min are still correct. For the second print out and there after. They are all correct. Did I miss something here?
Any help si appreciated, thank you.
Tony
