major bug cFP
I belive I found a major bug in both 8.5 and 8.5.1
If one places a cFP constant and then makes it into a control, to be able to browse for units instead, it works just fine in the devel. environment. BUT, as soon as you try to build it, you get an error saying necesary components are not installed. If you just place the components, you do not get the FP dll included either, suggesting that the feture should be included in the .exe, but no.
tried in 8.5 with 6.0 and 6.0.1 drivers and in 8.5.1 with included 6.0.1 drivers.
The reason I want is as a control is that I have several backplanes and several TC-125 modules that are swapped around, so i need a flexible solution so i dont have to rebuild the application as soon as we get another backplane or add a module.
Anders
Message 1 of 1
(3,061 Views)
