make a sequential 2D output
Hi all
i have to write a program that give some numerical inputs and after calculations make some other numerical outputs. these out puts should illustrate in a 2D arraye and table
but in each stage when user push next stage buttom labview should calculate that stage outputs and fill just this row in out put array and table for example in 2nd stage it should fill second row of out put indicators how can i do this?
please find my front panel in attachment file
(3,589 Views)
Keep the 2D array of strings in a shift register and use an event structure for the "Add Row" button.
WIth every press, add a 1D array using "build array". There are plenty of examples here in the forum.
(3,576 Views)
Accepted by topic author 12321254
Here's a quick example...
(3,573 Views)
thanks buddy
(3,540 Views)
