make a signal active or inactive for PXI-6514
  I have NI PXI 6514 Digital I/O device and let's say that I want to change the Signal P4.0 to inactive by sending + 3V or inactive by   having high-impedance value. My question is how I can write to this digital line this 3V using the Write Dig Chan. vi.
Thanks in advance,
Iliya
(2,991 Views)
the output voltage on PXI-6514 digital line is directly connected to VCC by a Darlington driver. Please see the link below.
http://digital.ni.com/public.nsf/allkb/8D46388A20C5A23E862572B8007E8C82?OpenDocument
Due to the diode in place, the output impedance measured between the positive and ground terminals is very high whether the switch (Darlington Driver) is open or closed.
You could send more details about your requirements.
Regards
Rüdiger
(2,969 Views)
