make a subVI do something on first call
I have a SubVI I made and I want it to do one thing the first time it's called and then as long as the program is running it should do another thing.  Right now I have a  "First Call" function wired to it, and that passes it a tru the first time my SubVI is ecounterd and a flase every other time... this works... but I was wondering if there is a way to do this from within the subVI itself?
Thanks!
(3,341 Views)
Accepted by topic author Fibo
Why don't you place the "first call?" primitive inside the subVI?
(3,339 Views)
because if i do that, the first call would be true every time the Subvi is run.... wouldn't it? let me try this... i didn't even bother trying cause i figured the first call thing would run every time the vi is run.... i'll be back
(3,333 Views)
You are absolutely right! I just thought... well... you know.
(3,332 Views)
