make approximately 1400 measurement and stop the program
I have a problem with my program and i do not know a solution. I start the program and make settings. Then I start the measurement and approximately after 1400 measurements the program stop to work. Maybe had someone the same problems and know someone the solution? I have the NI labview 2012 and Windows 8.
(2,588 Views)
It is very difficult to debug a VI (or VIs) without being able to see them.  Post your code.  Do not post "pictures" of your code, but attach the actual VIs.  If you have too many, put them all in a folder, compress (Zip) the folder, and attach the .zip file.
Bob Schor
(2,580 Views)
