making a numeric control or indicator display present and past values
How do you make a numeric control( or indicator) display a scrolling present value+ x number of the past values as the vi runs?
(2,432 Views)
You can do that with sift register in the case you need
only short term historic data, or you may use vague array
data with +1 dimension to a numeric, in which to put
historic data sequencially to the loop counter by replace
array element.
A little sorry for miserable grammatical conditions(-;),
Tom
(2,432 Views)
