making database of serially communicated data
Hi
I have connected sim900d module with the com port and real time data is being acquired. How can i make its database to present it. I have already made the gui for sending and recieving the sms
(2,475 Views)
Hi green,
I guess this is continued from that thread
What "database" are you talking about? You should have received a manual for your GSM module so you should find all relevant information in there. Otherwise ask the vendor for a comprehensive documentation!
(2,462 Views)
you can store the comming data in a file by opening a file and write the comming data in it. there are FILE I/O Vis (built in)  you can use them.
check this link also
Storing Data from Serial Connection
http://forums.ni.com/t5/LabVIEW/Storing-Data-from-Serial-Connection/m-p/2699427/highlight/true#M8017...
(2,454 Views)
