making the Dc voltage active in the code
Hi Johnsold,
Actually, I am trying to run the code but give me an error state that error -200479 occured at DAQms start as can be seem in atached file.
Khalid
Message 11 of 17
(985 Views)
Khalid,
The error message tells what needs to be done. First note that both DAQ tasks are set to continuous samples. A task that is set to continuous samples is done when? - When all the samples have been processed. When is that for continuous samples? Never. So I think you need to remove the Start Task VI in the event structure. These are the kinds of mistakes which occur because I do not have DAQmx and cannot test things.
Lynn
Message 12 of 17
(973 Views)
Hi Lynn,
I have removed the stsrat task in the event structure. However, i still get an error state that Error -200292 occurred at Synchronized AI and AO FRF_New (2).3 (1).vi, as can be ssen in attached file.
Khalid
Message 13 of 17
(961 Views)
sorry I forgot to attach the image of error.
Message 14 of 17
(960 Views)
Now you are getting into areas where I have no experience. Perhaps someone else will step in with suggestions.
Lynn
Message 15 of 17
(944 Views)
hi johnsold,
thank you very much for helping me. Do you know anyone who could help at this point as i am not expert in this field.
Khalid
Message 16 of 17
(941 Views)
Perhaps the best approach would be to start a new thread in the Multifunction DAQ Board. Link to this one and perhaps your other thread so that people can see what you have already done.
Lynn
Message 17 of 17
(930 Views)
