managing errors
I made this question in this thread (spanish community):
http://forums.ni.com/ni/board/message?board.id=6170&message.id=3270
but I needed another opinion.
"My VI have 5 while loops, that runs independents. Four of them have a process with a possible error.
On the other hand, 3 subVI of configuration (with possibles errors) running when start the VI.
My question: exists some method to stop de VI when it happens some error occurs without using local variables?
(I need 7 local variables in each loop to be able to stop them)".
vicen
LV 7.1 / WinXP
(3,077 Views)
Do you need to know which one caused the error?  I see you have 4 booleans.  What about the timing of each loop?  Are there any critical loops?  I would make an error handling subVI, but how it is constructed is based on the questions above.
The mechanism I use typically involves using queues to handle the error clusters.  If any error is queued, then it stops everything.  But there are other ways to construct this subVI.
Paul
(3,067 Views)
Here's one example. It could be made smarter, but it would work as it is too (and across VIs).
It resets the flag to F when it starts and sets it to T whenever one of the loops tells it to stop.
___________________
Try to take over the world!
(3,058 Views)
Thank you, Stradis & tst,
The queues seem very interesting. And the STOP are OK.
Thank you both.
(3,052 Views)
