manipilating data in arrays
If I have 2 index arrays one of Frequency vs Amplitud in dBm and the other of a Frequency vs attenuation in dB, the attenuation data is much wider range and different Frequency Values than the Amplitude data. Is there a way to apply the attenuation data on the Amplitude ? at the end I want to have a graph as accurate as I can of the Amplitude after the attenuation for each frequency of the first data, the amplitude data.I want in every frequency of the amplitude to get the attenuation effect for the same or closest frequency I have in the attenuation data.
I attached relevant files of what I got so far and the data.
Guy
Message 1 of 9
(4,263 Views)
Guy,
It always helps to do a lot of searching on the internet.  I found the following article that I believe creates a solution for you.
(search term - "uneven sample waveform LabVIEW")
http://digital.ni.com/public.nsf/allkb/53E96C82FF016576862574670052585D
I have attached an updated VI that generates the product you asked about.
Joe
Message 2 of 9
(4,239 Views)
Hi Joe,
Since I just started to learn the program I didn't know how to make a "Google" question out of it 🙂
Thanks for your help,
Guy
Message 3 of 9
(4,227 Views)
Hey Joe,
The solution you suggest does not working. the graph I get is just an inverse graph of the original amplitude data.
Would like to hear if there is another suggestion.
Guy
Message 4 of 9
(4,173 Views)
From your intitial post I assumed that you wanted to multiply one graph with the other.  Maybe there is a value conversion (dB to ?) needed for the attenuation graph.  I didn't look that close.  But I thought it was at least helpfull that you now have the wave arrays interpolated and the same dT or dF.
Message 5 of 9
(4,161 Views)
It was very helpful but still not exactly what I need . I need the attenuation (jig offset data) on the Ampitude data. I'll keep looking but thanks a lot 🙂
Message 6 of 9
(4,151 Views)
So you need both waveforms graphed on the same graph?  If that is the case you can build an array out of the two waveforms and put the array into a waveform graph.  If you want to show the an equal frequency range you can always find the shorter one and get a subset of the larger one before you plot.
Unless I still don't understand what "I need the attenuation (jig offset data) on the Ampitude data".
Message 7 of 9
(4,144 Views)
I need just one graph. The graph I need is the first data - the Amplitude with the effect of the second data - the attenuation. What I see in the third graph- "attenuated waveform" doen't include the effect of the attenuation.  The first 2 graphs are good to I just need to figure how to apply the second graph on the first one.
Message 8 of 9
(4,137 Views)
Thanks to you and with a few modifications now it's working 🙂
I attached the udated file.
Thanks again
Guy
Message 9 of 9
(4,125 Views)
