manipulating array of data
X_ValueVoltage - Dev1_ai0
02.47051
4.55E-052.468536
9.09E-052.475117
0.0001362.471169
0.0001822.475446
0.0002272.473143
0.0002732.473143
0.0003182.469523
0.0003642.468865
0.0004092.470181
0.0004542.470181
Hi, i dragged my signal from signal viewer into microsoft excel and i was given the above data (above is only a sample). i need to find a way of converting the x-data from freq to range. i have the formulae to do it - but i have not a clue on where to start. n e help would be great thanks.
(3,745 Views)
Use a read spreadsheet.Get the data into a for loop(index enabled) . Use your formula and get the out put.
(3,739 Views)
what do u mean a read spreadsheet?. read-only?
the formulae i have to convert freq to range is
range = freq*c*dT/(2*dF)
where:
c   = 3*10^8
dT = 0.02
dF = 66*10^6
How do u do index enabled?
do u know how to do for loops in excel?
(3,735 Views)
Why dont you continue in the original thread? You were getting the replies right?
(3,726 Views)
hi, no i wasnt getting any replies. 😞
(3,721 Views)
What do you mean by no replies. that thread is two page long remember. Be patient and continue in the same thread. Instead of starting a new thread you can give an elaborate explanation of what you want there to get it solved.........
(3,706 Views)
