manu ring case
I have a problem, I want to have a program consisting of a menu ring, case structure and 2 incator, when I select case 1 then indicator 1 will show its value if selected case 2 then indicator 2 will produce the value but indicator 1 still gets the previous value , please helpxx.JPG
(2,392 Views)
If you want the other values to be blank, set them all (provide empty string outputs for other cases)
If you only want to update a single indicator, place it inside the case structure.
GCentral
(2,372 Views)
