manually change ROI position
Hi...Smiley Very Happy
I was trying to change the ROI position in LabVIEW .
I dont know whats wrong with the Image control.
I have made the ROI offset (x,y) position so that it can change the vertical and horizontal postion of the ROI pattern. It is changing the position but in the Image it is unable to clear the old ROI positions.
I have attached my ZIP file containing VI and image please help me on this.
Message 1 of 10
(6,284 Views)
hI ,
        have you found the solution for ths post ..
Message 2 of 10
(6,118 Views)
Hey,
Actually the post is quite old.
But if you will use "IMAQ clear overlay.vi" it helped me to solve the issue in attached code
Message 3 of 10
(6,105 Views)
             I AM TRYING TO DO manual ROI seting .. for the flowing code.
              here I am using Vision Express.
              i have attached my Code
Message 4 of 10
(6,082 Views)
hi Mangesh D.,
               Have you found solution for Manual ROI seting using Vision Express ..
               If i got soultion this will be helpful in my programming ..
              waiting for your replay ... !!!!
Saran.
Message 5 of 10
(6,061 Views)
Hi , HAVE YOU FOUND SOLUTION FOR THIS ???
Message 6 of 10
(6,032 Views)
Hi saran1988
Using Vision Express VIs have there own limitations.
Setting up a manual ROI in express VI is difficult.
Why dont you use the VI attached in my first post?
All you have to do is put the code inside your producer consumer loop and add "IMAQ Clear Overlay.vi."
Message 7 of 10
(6,000 Views)
hi Mangesh D. ,
        I dont know how to add "IMAQ Clear Overlay.vi."
Message 8 of 10
(5,992 Views)
You're posting on a thread that is a year old.  If you're getting any replies, you're lucky.  Either be patient or spend a few minutes to go over the last post they sent you and try to understand it.  It's not reasonable for you to demand they reply quickly to hold your hand.  Learn to use Ctrl+H to understand the tools they provided you.  At some point, you'll need to be able to understand what you're doing.
Message 9 of 10
(5,966 Views)
Thanks for the Good advise 🙂
Message 10 of 10
(5,396 Views)
