map display as switches
OK, I forgot to make the values of FP controls default, so it will be more difficult to test the VI I attached in the previous post.
This is the the VI with reasonable values set and btw I altered the Input data format a bit.
greets, Dave
Greets, Dave
Message 11 of 16
(1,885 Views)
Many thanks for all the replies and the time taken to post example code, it really has been appreciated. The application I am coding is of personal interest rather than a true deliverable, but its been interesting along the way - defining the County boundries as numeric arrays took a few hours! but these had to be accurate in Lat/ Long format.
In the end I chose to use the mutli coloured map and the Mouse Move event rather than Mouse Down, this works great. I also used the "InROI.vi" within the application to sort through thousands of locations and distribute them to reside within their specific counties - I had found this vi a few weeks ago while searching the forum and had this part working very well.
So what does this little application do - it counts up Speed Camera locations in the UK offering statistics for each county, a strange thing to want to do, see the attached image (sorry about the size as I use a large monitor when running this! Next I will colour code the dots to diferentiate between the different types of camera! - Thanks all - Mike
Message 12 of 16
(1,855 Views)
- Mike
I always think such projects are very good for your skills, better than homework!
Good luck,
Ton
My LabVIEW Ideas
Message 13 of 16
(1,848 Views)
TonP wrote:
- Mike
Good luck,
Ton
Ditto That!
Some of my best code was developed in my basement as an experiment to see if I could do it. The hard part comes latter when I have try and figure out how I will squeeze that new idea into an application, just "because I can"*.
Ben
* I believe it was Jeff Goldbloom's character in Jurasic Park that quiped "Often people are so wrapped up asking  'could we do something' but fail to stop and ask 'should we do something?' ."
Message 14 of 16
(1,840 Views)
Mike, after you finish the VI, you should hook it up to a GPS unit and run it on a laptop to provide alerts before you reach the cameras. You can then send it to Top Gear. I'm sure they'll like it. 🙂
It was.
___________________
Try to take over the world!
Message 15 of 16
(1,833 Views)
I use a PDA with Labview running on it from time to time for mobile GPS applications although the car is equipped with three roof mounted GPS receivers and a built in PC so a warning system could be coded up quite easily - Mike
Message 16 of 16
(1,825 Views)
