map with LabVIEW
hello all,
I wish to know, if it is possible to use map like in C++?
I have 2 arrays, one of string and one of dbl. The user need to write a name of parameter in string control, and after i need to find the value of this parameter by a searching in the string array. It's a long solution. And i need to do it many times. It's for that i have thinking of map in c++
If someone can hlep me ^^
thanks
Message 1 of 8
(6,660 Views)
Hi mioumiou,
this should work for you.
Mike
Message Edited by MikeS81 on 02-10-2009 11:52 AM
Message 2 of 8
(6,657 Views)
thanks a lot for your quick answer.
I thought about this solution, but the problem, it's that i will have a array of 500 or more parameters, and this solution, will take a little bit of time to find just one parameter. And for each iteration of while loop, i need to make this research 500 times. This will take a very long time.
I think about map in c++ but if you are a better idea, i take  Smiley Happy
Message 3 of 8
(6,651 Views)
Accepted by topic author mioumiou
Message 5 of 8
(6,615 Views)
thanks a lot,
variants seems to be the solution.
thanks thanks thanks Smiley Happy
Message 6 of 8
(6,605 Views)
Many thanks, Phillip for point to these links. I was pretty skeptic about attributes before. But it just incredible!
Just done quick test - searching 25000 lines in 80000 strings dictionary taking approx. 22 seconds with search array, or 6 seconds with small improvement or just 20 milliseconds with Variant attributes.
1000 times faster... Still can't believe...
Andrey.
Message Edited by Andrey Dmitriev on 02-10-2009 04:01 PM
Message 7 of 8
(6,581 Views)
For a while we had a prototype of a generic map container on NI Labs.  It is listed now as a "graduate" which I think means that it should find its way in the product at some point.  You can follow the discussion and ask questions here.
Travis M
LabVIEW R&D
Message 8 of 8
(6,574 Views)
