marked element of listbox
How can the marked element of a listbox be displayed in a string indicator?
The problem is, a function to sort the list is used. So using the indices isn't possible, cause the elements accordant to those arent the same after sorting the list. Is there a propertie node or something that gives direct access to the marked element of the lisbox?
Thanks Volker
(2,422 Views)
Hi Volker,
if the values are in you ListBox, you can read them with a property node. See the attached example.
Mike
(2,419 Views)
