marking VI as top-level during build
While building an LLB, is it possible to specify VIs as top-level. I was not able to see any option for this in build specifications. I am using LabVIEW 8.6.
Thanks!
"A VI inside a Class is worth hundreds in the bush"
യവന്‍ പുലിയാണു കേട്ടാ!!!
(3,309 Views)
An llb is just a container, no something you "built" like an application.
You define the toplevel VIs of an llb in the LLB manager. Simply select the desired VI and do a "rignt-click...toplevel"
When you built an application, you define the "startup VIs". Could you be a bit more specific what you are actually trying to do?
(3,299 Views)
Hi altenbach,
In project, under Build Specifications, I was creating a Source Distribution. There under destinations page I selected Destination Type as LLB. When I create the LLB, all VIs are created in the samelevel in the LLB. I was just wondering whether there is any way of setting a VI as toplevel during the creation process other than by opening the created LLB in LLB manager.
(3,292 Views)
Accepted by topic author kikiduu
In the Source Files settings page you can mark files as top-level.
Remember you can only include LabVIEW files inside an llb
Ton
My LabVIEW Ideas
(3,271 Views)
Thanks Ton!
Somehow I didn't see that option  Smiley Happy
(3,268 Views)
