mass compile -> many errors
After an upgrade to LabVIEW 7.1.1, I went through a mass compile, and the resulting set of error messages gave me pause. I proceeded to uninstall and reinstall LabVIEW, followed by an immediate mass compile, but this still brings a number of errors (mostly example-related). Now, I've not run into any problems with the functionality I'm trying to use, but this does bother me a bit, as I'd rather not have to run into it in the future, and I've seen no mention of it elsewhere. I've attached three error logs, the original with (I believe) 7.1.1 and a bunch of add-ons, a bare 7.1 install, and a 7.1 plus NIDAQ install. Curious to hear what the problem could be, or if I whould just ignore this.
(3,261 Views)
(3,256 Views)
(3,258 Views)
There's a kb that says some of the VIs that you try to mass compile (examples) will also have a CIN Node included in it, and the mass compile will fail on those. Also, some of the VIs will not have a block diagram, and so an error will appear on those as well. Lastly, be sure you have administrator priviliges or root access when mass compiling.
KB Note that this was written for LabVIEW 6.0.2, but it still applies for 7.1.1.
Jeremy L.
(3,220 Views)
