massquage d'une image
Bonjour, Actuellement sous Labview 2011, j'ai deux applications(client tcp/serveurtcp) dans lesquel j'appelle differentes image pour les transmettre. Ceci fonctionne très bien .mais ma question c'est:
 comment massquer et démassquer l'image à transmettre.merci beaucoup
(2,306 Views)
Hi Khadija,
I will talk about your question in English for now (as I believe I understand it), and if you request it, I will follow up with an answer in French. You want to demask and mask images that you are sending and receiving. When do you want to do this? Are you wondering what functions to use?
This function might be able to help you, if you have NI-Vision.
http://zone.ni.com/reference/en-XX/help/371361H-01/lvpict/create_mask/
Ravi A.
National Instruments | Applications Engineer
(2,290 Views)
