.mat file to .wfm file?
Hello all,
I have a .mat file (attached) with a BLE waveform which I would like to transform into a .wfm file so that I can download it to my Keysight E8663D PSG.
From reading online, I have installed the native MATLAB IO data plugin and managed to open the contents of the .mat file
but I am not sure how I could transform it to a .wfm. This is something that the MATLAB IDE can do for you but I was wondering if LabVIEW has any kind of automation for that.
Has anyone encountered a similar task before?
Thank you,
Alex
(567 Views)
Hello Alex,
I cannot read your .mat file so cannot verify the following solution. However, have a look at using the 'build waveform' function block and then feeding the output into the MATLAB DataPlugin functions using the steps below:
  1. Open and Write Data Storage:
    • Use the data plugin’s Open Data Storage function to create or open a file where your waveform data will be stored.
    • With the data storage reference, you can use appropriate write functions to store the waveform data.
  2. Close Data Storage:
    • Remember to close the data storage reference once you’re done writing to ensure that all data is properly saved and to free up resources.
This link on creating/modifying .mat files may help: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000001DmPyCAK&l=en-GB
(413 Views)
