match first string
Hi all,
Anyone have any example VI for "match string first" function?
Thank you 🙂
(5,052 Views)
try placing this snipped on a block diagram:
Marco
(5,036 Views)
Thank you! Is there any way to set array to case insensitive? 🙂
(5,034 Views)
There is no option to make it insensitive instead you can convert both the array and the string to upper case and pass it.
(5,026 Views)
Accepted by topic author joseleen
Something like that should do (almost) the trick.
Marco
p.s. almost because the output string will be lowercase.
(5,025 Views)
Is there a way that I can use a variant for string?
Because I need to check for 4 strings instead of only 1 string to match.
(4,951 Views)
