match measurement profile
hello ni,
                 i have two reference one is displacement and torque. i want to plot the graph x-in displacement and y in torque. at first i have to take the master data then i will compare this curve on next components. i want to check the measurement data with master data if its equal also i will give the tolerance band for measurement data.
can you give me a logic for this.
Balaji DP
(2,496 Views)
Hi Balaji,
Could you post some examples of the Data you are getting and perhaps some code you have tried already. Once i have some more info i will take a look for you,
Rgs,
Lucither
"Everything should be made as simple as possible but no simpler"
(2,467 Views)
