match pattern
I use the "Match Pattern" function to extract a number (the data is temperature), with the following expression: "[0-9]*[\. 0-9][0-9]*" It works, but the minus sign is lost for negative temperatures. How can I solve it?
(3,076 Views)
If you use the pattern "[0-9\-][0-9\.][0-9]*[\.0-9][0-9]*" it should work.
Best of luck
Tim Norris
"...and all this science I don't understand
it's just my job five days a week"
Using 6i, 7.0 & 7.1 on Win'98, 2K & XP
(3,072 Views)
