match pattern
I am having a problem with my vi. I am using the match pattern string vi, as an input i have: the measurement is:
a simple string and match pattern is suppose to find : Unfortunately it gives me an error..
Not sure how to fix it.
Message Edited by GHernandez on 11-02-2005 04:03 PM
(4,787 Views)
What do you mean when you say "it gives me an error"? Your screenshot does not show a broken run arrow so the VI compiled. Are you saying that the "offset past match" output is -1? If so the Match Pattern function didn't find your search string. It's hard to tell from the screenshot, but are you looking for ":" (just a colon), or ": " (colon with space after it)?
(4,774 Views)
I apologize for not being specific. I get the following error:
Error1 occured at Scan from String (arg1) in build_string.vi -> File Write.vi
Possible reason(s):
Labview: An input parameter is invalid.
When usign the match pattern function, i am searching for ": "
basically a colon followed by a shift.
Message Edited by GHernandez on 11-04-2005 05:03 PM
(4,753 Views)
What i was trying to say is that its a colon followed by a blank space.
(4,743 Views)
@GHernandez wrote:
When usign the match pattern function, i am searching for ": " basically a colon followed by a shift.
What is a "shift"???
Why don't you attach your VI instead? It would be easier to troubleshoot. 🙂
(4,741 Views)
Look again at your error message:
Possible reason(s):
The error occured at Scan from String, not from Match Pattern.  You have an input string wired, but no format string.  You need to wire in a format string.
- tbob
Inventor of the WORM Global
(4,738 Views)
