matching sampling rate between RT and FPGA or upsampling
I'm doing realtime signal processing, and LMS system identification
obtain signal from microphone and emit sound from speaker
most convolution process is conducted in RT
So i send data from RT to FPGA
not vector just sample data
problem is because sampling rate of Timed Loop in RT and Data rate of NI c series is not match slightly
the system identification FIR filter is not converge.
while processing, the coefficient is slowly move toward left. i suspect the gap of sampling rate between RT and FPGA.
but when i run with Full speed of Data rate, the problem could be overcome.
however there is a big problem. because i send a sample data from RT to FPGA, if data rate of FPGA is 3times bigger than RT.
Speaker emit sound like 1 0 0 2 0 0 3 0 0 2 0 0 1 0 0. original signal is 1 2 3.
So i have to interpolation in FPGA
I know i can you resampler VI. but i don't know how i use is VI correctly......
please show how could i upsampling in FPGA
Message 1 of 1
(964 Views)
