math script error
hello
i am facing issue when i am running amplitude modulation example on my system having labview 2017 version (32 bit) it is showing math script server error.
please tell me the way how to resolve this error.
here i attached one screenshot please take it as reference.
Message 1 of 10
(5,751 Views)
Hi certified,
are you sure your screenshot is related to your problem?
(And according to your tags: is LabVIEW NXG involved in any way?)
Message 2 of 10
(5,719 Views)
By mistake i put nxg sorry for that but do you have the solution?
Message 3 of 10
(5,716 Views)
Hi certified,
a solution to an "Agiltron 8-Bit Switch"?
Message 4 of 10
(5,710 Views)
no idea about what are you asking? I think aglitron is not related with my problemSmiley Frustrated
if you don't have answer than wait for others replySmiley Indifferent
Message 5 of 10
(5,708 Views)
Hi certified,
I ask again: is your screenshot related to your problem?
Please check that screenshot of yours!
Message 6 of 10
(5,698 Views)
sorry for that screen shot i select wrong file
here i attach right screenshot
thank you
Message 7 of 10
(5,679 Views)
Hi certified,
so the questions are:
  • Is MathScript installed?
  • Do you have it licensed and enabled?
  • Do you have other VIs with a MathScript node that are working?
  • Is there some special command in the MathScript node? (As you only attached an image of your code instead of real code we cannot examine your VI!)
Message 8 of 10
(5,667 Views)
yes mathscrip is installed
yes it is enabled
no i don't have other vi that are working
don't know about special command
Message 9 of 10
(5,665 Views)
Hi certified,
so MathScript is installed and enabled, but you cannot open or create any executable VI with a MathScript node in its block diagram?
Then I guess a problem with your LabVIEW installation.
Simplest (but still annoying) solution is to reinstall LabVIEW (first deinstall it, then install it again)…
Message 10 of 10
(5,663 Views)
