mathscript function 'resample' generating out of memory error
Hi.
So, I find that calling the mathscript function like the following:
resample(array, p, q)
generates a memory is full pop up and the program stops running
if q/p > 3.
This happens even if my VI only contains a mathscript node with this
call and no other app is opeon.
Any ideas?
Thanks...
-Umar.
(2,913 Views)
Can you post you VI? I need to be able to reproduce the error myself in order to further investigate.
Eli S.
(2,896 Views)
