mathscript in the vi is showing the error
i'm using ni-6008 to sample voltage and current.
the values obtained are in the form of 1D array.
these values are given to the shift register to have the difference between present value and previous value.
the difference is given as input to the mathscript for the program written as shown in the vi.
i hope, i'll get the difference between two successive elements in 1D array  and this is fed to mathscript module.
but when i run this vi, it is showing an error as shown
how to rectify this error? and also
if we give 1D array as input to mathscript and it is unable to perform comparision operations ( such as greater than, lesser than etc.), then what is the modification shall i do?
please suggest me some solutions
Message 1 of 10
(4,277 Views)
Hi trip,
easiest solution would be to replace the mathscript code by "standard" LabVIEW G code!
To start you could replace the first 4 lines by InRangeAndCoerce…
Message 2 of 10
(4,252 Views)
yeah, i've tried that method.
the problem is i'm feeding back the d value for every iteration. i'VE TO update the d value
Message 3 of 10
(4,222 Views)
I don't think you understand the difference between an array and a scalar. Your script has scalar (single value) variables defined but you are feeding it multiple values as an array. I don't see anywhere your comparison of a current value to a previous one. The image is incomplete. I would also recommend using native LabVIEW functions.
Message 4 of 10
(4,211 Views)
then please suggest me some way to take the difference of successive values in an array.since sampled voltages are in the form of array
Message 5 of 10
(4,205 Views)
Hi Trip,
to get differences between array elements you can calc like "array[1]-array[0]"!
Either use an autoindexing loop or subtract the subarray starting with index 1 from your original array…
Message 6 of 10
(4,184 Views)
can anyone give me the link for the mathscript module syntaxes for the functions? i've tried. but unable to get the required data.
i mean, I NEED ALL THE POSSIBLE SYNTAXES REQUIRED AND ARE PRESENT FOR THE FUNTIONS PRESENT IN MATHSCRIPT MODULE.
 for example, the syntax for 'for' loop is
for m=1:10 , for m=1:0.1:10, etc.
so i need some pdf that gives all tthe posssible syntaxes for the functions in mathscript module.
and i need one more qlarification. is both mathscript and matlab are same?. shall i use all the syntaxes of matlab functions in mathscript. if not, show me some pdfs that tells the correction to do( i mean the proper syntax and format)
Message 7 of 10
(4,145 Views)
You can use a For loop (to index through your array) and a Shift Register (to hold on to the previous value) to convert an array of data into an array of (data(i) - data(i-1)).  Here I've created an array of 100 random numbers between 0 and 1 ("data") and then used the For loop + Shift Register to compute the Delta array (with an implicit assumption that the number before the first point was 0).  You can do it all in LabVIEW (and should do it all in LabVIEW).
Bob Schor
Message 8 of 10
(4,063 Views)
Hi Trip,
Have you tried to read the LabVIEW help? The help for the mathscript node?
It explains all the functions and their syntax!
Message 9 of 10
(3,850 Views)
yes. i've tried. there very less explanation is given.
Message 10 of 10
(3,834 Views)
