mathscript labview 2011... Where can I get it?
Hello everyone,
I need to use MathScript Node with my project to manipulate signals. But I cannot find it in my LabView 2011. I followed this web http://www.ni.com/white-paper/3256/en/   but in my labview2011, it didn,t show the MathScript Function. Anyone knows how I can get it?
(4,063 Views)
It's an add-on that you purchase - http://sine.ni.com/nips/cds/view/p/lang/en/nid/209854
(4,045 Views)
If that is only one way to get it, I don't think that I can purchase it now. However, I tried to use MatlabScript to manipulate signal from DAQ Assistant. I change the signal from dynamic to double by using convert from dynamic data function, but it cannot send the data to the MatlabScript. The notice is " Error 1047 occurred at LabVIEW:  LabVIEW failed to send variable to the script server. Server:"" in Array_Practice.vi". Anyone knows how to solve this?
(4,032 Views)
The matlab script requires you to have matlab installed.  Do you?
(4,005 Views)
Dear natasfaw,
I installed it already. I tried it with a simple code and it worked. However, when I tried with analyzing code which processed more data, it stucked and stopped executing. Do you know what is the differences between MatlabScript and MathScript?
(3,987 Views)
One requires Matlab to be installed.  One doesn't.  The first is going to make a call into your Matlab installation to process the data.  The second is going to make a call into its own engine to process your code.
(3,966 Views)
