mathscript lock in 8.2
hellow one and all,
i just got labview 2010.  i had some old code in 8.2 to port over and the only code that is unfound in 2010 is the mathscript.  so i installed 8.2 on a different machine so that i can see the code and convert it over.  under 8.2 the code opens fine, except the mathscripts do not expand bigger or open for me to see all of the code in the box.  how do i unlock the mathscript box so that i can see the code?
how come mathscript is not a part of labview 2010?  thanx in advance.  lucas
(3,033 Views)
Did you try a search? This has been asked before. Mathscript requires its own license as of LabVIEW 2009.
(3,029 Views)
search under where, what am i searching for?
(3,022 Views)
In the search bar in the top right part of just about every page on this site you can enter : mathscript 2010. The third link, for example, points to the product page. If you narrow the results to discussion forums you will see this question has been asked many times.
(3,002 Views)
