mathscript node-image processing
Iam trying to incorporate matlab user-defined image processing function FRST in labview as I could not find a vi assosiated for it. I obtained this function from the internet and I implemented it in matlab and it works well.Now i'm trying to add it to labview using the mathscript node.This function requires an input image as a parameter .As there is no imread function in the script file how am I Supposed to input the image grabbed from my webcam in labview to the script node function?
Also FRST function calls another user -defined function and a mex file, will labview automatically search and run these functions???I have added the search path to this folder in the mathscript window, is this enough?
(3,642 Views)
Duplicate post; follow the discussion in the other thread.
(3,530 Views)
