mathscript node
I'm new with using LabView and I'm trying to use the mathscript node, but I'm getting an error an, "unexpected token error".  I have attached the vi if that helps, but anyways I'm trying to input 3 numbers and then do some math operations and ouptut two positions.  The three inputs will be data from a DAQ, but I'm just using numeric controls to test the program.  It seems like the mathscript node does not like more than one input, but I know it can do it from examples I've looked at.  Would someone be able to help me out with this?
             Pete
(3,304 Views)
Try writing your first line as W=A+B+C;
Your assignment logic is backwards.
(3,297 Views)
Hi Pete,
apart from the order error the mathscript node is (IMHO) the worst structure you can choose for such a simple calculation.
See attachment to have 2 more options to do some math...
(3,283 Views)
Thank you very much guys for the help.  It works beautifully now.
Pete
(3,256 Views)
